mopar 3 B
- 11:50 AM
- Aug 25, 2014
- Kingsville, MO
How do I go about checking for the shaft?
I didn't use a Fram filter. I used the Mopar brand One.
When i drained the fluid it felt very thin, per se. Nothing shinny rolling through it. Saw a leak coming from the arm where the filter attaches. Is there a way to tighten that bolt without pulling the engine or taking off the headers?
Sorry about the filter. Someone had a high respect for the Fram's. If you are getting oil on the trans have you checked the oil sending unit fitting or gauge lines for leakage back by the distributor? Also if you had the engine running for 20 minutes there was no reason to pull the distributor to prime it after 20 minutes the pump should have been primed or your engine locked up from lack of oil.
As to the filter mounting you do have the 90 deg extension for header clearance? The direct to the block filter attachment will distort if the filter is attach to tight - hand tighten only.
