DWinTX
I have a Weiand 7503 aluminum manifold that I'm using on my 65 poly build. I bought it used a couple of years ago and just went to test fit it in the engine. There is a plug in the intake floor below the thermostat housing that someone plugged with what looks like a plumbing pipe plug with a square head. The problem is the head hits a casting boss in the lifter valley. I'm sure this was meant to be plugged with a hex head style plug, or at least inserted from the top.
The problem is that it won't come out. I put the intake in a vise and used a long breaker bar but it won't budge. I PB Blasted it and let it set for an hour, still won't move. Tried whacking the wrench with a mini sledge, no go. I think it may have been stripped. So the question is, would there be any problem cutting the head off flush with the bottom of the intake? I don't know why it's even there, so I can't think of why I'd ever have to remove it since it would open a coolant passage into the lifter valley?
But, these intakes aren't made any more and there are no others made for a poly. Used, these are now going for $500-$700. So I don't want to screw anything up. Does anyone know why that hole is there and if it would ever need to be opened?
