Any ideas why the trans is slipping when put in gear? It's behind a 451. It was rebuilt for the engine, 4 years ago. 370 hp 460 tq at the wheels. Everything was fine, pulled in the drive, shut it down, fired it up 5 minutes later went to back out no solid engage. Gave it some gas, started moving, put it in drive same thing. Once it started moving it shifted fine. Drove it home about11 miles. When I got home, checked fluid, a little low, looked good color wise, synthetic fluid smells burned anyway so no clue there. Fired it up same thing pulling it in the garage. B&M converter, screen filter haven't drained fluid (plug) or pulled the pan. Bands, converter, any other thoughts suggestions? Thanks in advance! Howard
