69 gtx
I was going to but thought with the rockers & lift it might collapse the lifter.
engine **** alert!!!!!!!!!!
Tim Borrall 440 010.jpgTim Borrall 440 011.jpgTim Borrall 440 012.jpgTim Borrall 440 013.jpgTim Borrall 440 014.jpgTim Borrall 440 015.jpgTim Borrall 440 016.jpg
Tim Borrall 440 017.jpgTim Borrall 440 018.jpgTim Borrall 440 019.jpgTim Borrall 440 020.jpgTim Borrall 440 021.jpgTim Borrall 440 022.jpgTim Borrall 440 023.jpgTim Borrall 440 023.jpgTim Borrall 440 024.jpg
Tim Borrall 440 025.jpgTim Borrall 440 026.jpgTim Borrall 440 027.jpgTim Borrall 440 028.jpgTim Borrall 440 029.jpgTim Borrall 440 030.jpgTim Borrall 440 031.jpgTim Borrall 440 032.jpg
Tim Borrall 440 033.jpgTim Borrall 440 034.jpgTim Borrall 440 035.jpgTim Borrall 440 036.jpgTim Borrall 440 037.jpg
Jim said the intake didn't fit right and will need milled so it will be next week for the dyno.
Tim Borrall 440 010.jpg Tim Borrall 440 011.jpg Tim Borrall 440 012.jpg Tim Borrall 440 013.jpg Tim Borrall 440 014.jpg Tim Borrall 440 015.jpg Tim Borrall 440 016.jpg Tim Borrall 440 017.jpg Tim Borrall 440 018.jpg Tim Borrall 440 019.jpg Tim Borrall 440 020.jpg Tim Borrall 440 021.jpg Tim Borrall 440 022.jpg Tim Borrall 440 023.jpg Tim Borrall 440 024.jpg Tim Borrall 440 025.jpg Tim Borrall 440 026.jpg Tim Borrall 440 027.jpg Tim Borrall 440 028.jpg Tim Borrall 440 029.jpg Tim Borrall 440 030.jpg Tim Borrall 440 031.jpg Tim Borrall 440 032.jpg Tim Borrall 440 033.jpg Tim Borrall 440 034.jpg Tim Borrall 440 035.jpg Tim Borrall 440 036.jpg Tim Borrall 440 037.jpg
This is cool stuff that I haven't told the ol' 69 GTX yet. This mostly a street car so I was shooting for a good safe 10.0:1, We got 9.9:1, I might try 87 octane.......might. Then we did something on the sneaky side, kinda like this guy did to his wife when she went in for a breast augmentation, told the doctor to put in one size larger (told to me as a true story). Well, he got one size longer cam. We put in a solid roller 238/242 @ .050, the equivalent of a 232/236 @ .050 hydraulic. Man it should idle good but a 3" exhaust will rattle the china in the display case.
We have .240/.309 piston to valve clearance (couldn't believe it so I checked it three times) so I guess I should have gone 276/280 @ .050".
Head cc's.....
Smallest 77.4 and biggest 77.6. The valves only varied + or - .0015 in length and one was .001 out of round. The seats in the heads were round to .0015" so I left them alone. I was able to set the installed heights by shifting the retainers and locks around so that the installed heights varied by no more than .009", 1.987 to 1.996. Didn't even bother to use any shims just put the strongest springs on the longest and the weakest springs on the shortest.
Didn't like the .0006/.0007 valve to guide clearance so we upped it to .001/.0012, that's just me.
Too tight can cause trouble and grab if valve heats before the guide and the rest of the head
so good move
Hard to tell from the pictures, but it looks like you smoothed out both the intake and exhaust ports correct?
I also like the idea of a little more valve guide clearance. I will be sure have that checked out on my heads.
Can't wait to see how it fairs on the dyno.
Thanks for the update Jim! We all are just holding our breath to see what #s it will put up on the first session on the dyno. Any predictions from you Jim????
I am hoping for 600 on my 540, sort of hoping it stays below 630ish... it is another step up in cash over 630...
So I did get a little done over the weekend. Put the new wiper motor on.
While I was digging for parts I found a couple old aircleaner piepans. So I put them up on the wall for artwork.
Started taking the dash apart to restore. I was thinking I may use the empty spot on the right side of the speedo to make a light for the OD when on. It would mirror the high beam indicator. Do you think green would be a good color for that guys?
I was thinking of copying the washer button and putting right next to it on switch panel.
The overdrive button that is.
So I got some bling last night in the mail. SS and for 3" exhaust.IMG_20160301_161011.jpg
So I started getting motor mount stuff together and took a closer look at the Schumacher motor mounts I ordered. WTF is this! Why is the hole .7 for a .5 bolt!!!!
Looks like I'll be making some bushings to fill up the gap. I'd expect a lot better than this for the price I paid. With the HP Jim's going to make with the engine I don't want these being sloppy. Anyone else notice this before?
I like what you're thinking on the Overdrive light and button. Will be a custom piece retaining a stock look and I'm a fan of that.
I have the same 3" tips and happy to see you're going with 3" Exhaust because I'm pretty sure Jim is giving you a heavy breather!
As far as the Schumacher mounts that is disappointing. I'd be contacting them instead of making a bushing given the cost. I went with the Mity Mounts from 440 Source and a Schumacher torque strap. In fact I may part with the torque strap since I'm not sure how it will incorporate now that I'm going aftermarket K Frame.
Goon I also plan on electric cutouts for pissing off the neighbors.
