pwtjr
In the process of freshening up a mild 440 in my 69 Superbee. Decided to put a set of Trick Flows new cylinder heads on it. Thought about this for a long time. I was down to buying either a set of Edelbrock RPM's ported by Hughes, Indy EZ's, or these Trick Flow Powerports.
Hood clearance, header fitment, price, and reputation were my main deciding factors.
Anyway...
Upon unpackaging everything, they look pretty sexy. This is my first set of CNC'ed cylinder heads.
MY QUESTION IS: What is the surface finish of a typical CNC'ed port? Mine have a bit of a texture to them. I assume this is desirable on the intake side of a carbureted engine, but what about the exhaust side? Would it be a good idea to smooth out the exhaust ports?
I just received the heads yesterday, so I am still just looking and admiring them, but I plan on disassembling them, cleaning and inspecting everything, and have a shop check the spring rates are in fact as advertised by Trick Flow.
If there is something to gain by a little work with a cartridge roll, obviously now is the time to do it.
Anyway...
