Grabinov911
- 12:39 PM
- Jan 27, 2012
- Southern California
I'm assuming you haven't bought the kit yet and are just measuring it up? If you want I can measure a few things.
Yup. I'm trying to figure out how much room is going to be left for an electric fan/shroud unit. I actually thought that switching to a serpentine system was going to give me MORE room for the fans, but because of the position of the pulleys, it looks like I'll actually have less. As you point out, my furthest forward belt is the water pump pulley, which is a single groove pulley and which is recessed over the pump flange. With the serpentine system, I think I may loos about 3/4" of space, and rather than being tight only in the center as is the stock system (everything else is behind the water pump belt), it will be pushed forward 3/4" for the entire width of the engine.
The compressor I have is also a Sanden 508. It's 8 3/8" from the rear bolt to the front of the clutch (in my case with a 2-groove pulley). Given your spare 1/4" behind the compressor, your serpentine belt must be about 8 3/8" + 1/4" from the front of the head, or about 8 5/8"
