- 5:56 PM
- May 14, 2011
- On the Ridge, TN
Thanky kindly, sir.Sounds good Ed, Hey I wouldn't put much worry yet into the plugs looking like crap, You been messing with carbs and tune ect. You need a decent up to temp road trip on a set of fresh ones to get a true picture.
You ever pull the bulk head connector apart and look for green fuzz growing
Your going to get this figured out Ed I have no doubt, between all the advice you have got and your dog with a bone temperament I have faith in ya buddy.
Decent comp test , pretty much confirms what the prev owner told you about the build.
Yeah, I actually have had that connector apart, mostly exploratory in nature (and to make sure that infamous burn-out situation with the charging line going to the gauge wasn't happening).
I think my next area to research is how this electronic ignition system is wired. The twin ballast is new to me and I've converted several of these to electronic using the kit over the years, never seen a dual ballast before on 'em.
That voltage to the coil is bugging me still, too.
I need to get a proper wiring diagram going here.
