Grabinov911
Hey Guys,
Last Thursday I was out at Willow Springs with the Spring Fling crowd. I did a couple of morning sessions on the racetrack with the group and the car performed great. Then I went out for the High Noon drag races, and had a good time there too. Eventually lost a drag race to a Hellcat (big surprise), but I had him at the 60'!
Then I pulled into the pits for the car to cool down. I returned a few minutes later to find a small puddle under the radiator. It took 'till I got home to figure out what had actually happened, but when I got the fan and shroud off, I was able to see the following:
I am running a Wizard aluminum radiator and shroud with an engine driven fan and a standard Mopar fan clutch (removed in the photo). At some point during my track day, I believe during the drag racing, the fan clutch and the radiator came together, closing the 5/16" gap between them and adding an additional 3/32" dent into the radiator. I say it that way because I'm going to ask YOU to tell me what actually happened. Did the engine move forward enough that the fan clutch hit the radiator? Or did the radiator and core support move? (Seems unlikely but someone here besides me is the drag expert).
The engine is "tilted back" in the car compared to the core support and the radiator, which explains why the fan clutch touched the radiator "at the bottom of the circle" instead of in an even circular pattern.
Drag Race Experts: I get that the engine wants to rotate under torque, hence torque straps, chains, etc. But does it move FORWARD in the car under a hard launch?
