showard
CoronetDarter, How did you replace the old rubber stops?I bought one of those rear window roller kits for my Coronet. You're right, the rollers aren't a high wear item. Mine had deeper spider webs radiating from the center than your picture so I went ahead and replaced them. The biggest bang for your buck is cleaning the tracks; the original grease turns to petrified peanut butter. I dressed the tracks with 0000 steel wool, light grease, and now the windows roll up and down better than new.
I noticed that about the old grease. I had to scrape that "petrified peanut butter" off with a chisel and scrub everything in a lacquer thinner bath. Then I re-greased all of the moving parts and put a thin layer on the tracks. My next challenge will be trying to mount everything back correctly.
I am having a hard time not using new parts that I already have. I think that I will still replace the press on rollers.
Before:
After:
