68 Charger tail light/ brake light and marker light problems
Hazzard Lugnut
10:51 PM
West Virginia
Mopar family I'm in need of some help with the rear lights on my Charger. I have signal lights on the rear but no brake, tail or side marker lights. There is power at the brake light switch and when the pedal is pushed there is power on the other side of the switch but nothing to the rear other than power to the signal lights. I have new M&H wiring. Does the dome light switch have anything to do with it?
check behind the left kick panel at the plug, also check all fuses with a test light
Thanks for the reply. All fuses check out good and I checked the plug behind the kick panel and I only have power to the signal light wires.
everything runs through hazard switch & turn signal switch. & the running lights come from headlight swtch
