Need some help decoding my 73 Charger fender tag...
drobertson
10:21 PM
Wyoming
I bought my Charger a while ago, and I'm trying to figure out what it would have looked like from the factory. As far I know, it's Y2 yellow with A/C, 318 2bbl and heavy duty 727 transmission .
Ok, so here is what I know.
The top line of numbers, I have no idea.
G11 = Tinted glass all round
V1W = White vinyl top
U = Spec for USA market
WH23:
Dodge Coronet,Charger
High
2 Door Hardtop
G3A: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
1973
Lynch Road, MI, USA
246132: Sequence number
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
JY3: Light Gold Exterior Color
S1Y4: Trim - Unknown, Unknown, Gold/Black
JY6: Gold Poly Int. Door Frames
517: Build Date: May 17
Hope this helps
Lynch Road tags are harder to decode.
Not everything is coded.
We have a resident expert member- 69coronetrt, that's really good with the "gate sequence" numbers on the top row.
318 cars came with the 904 and not the 727 TorqueFlite (as far as I know)
Mine had a 727. Not sure why, but it does. The original owner WHO bought the car brand new says the transmission has never been replaced.
17=GATE number
156= BASE number
244005 = body sequence production number.
All of the above are related to production of the Body In White or bare shell of the car.
177= engine assembly = B body 318-2bb with A/C and automatic transmission.
981= rear axle assembly. Not sure of the specifics but...B body rear end. It's an 8.25 rear end with 2.71 gears; no sure grip. The brake size would also be included in this assembly number but I do not know what size they are.
053= transmission assembly number = 3681053= 727 automatic transmission for a 72-73 B or C body; 318/360
U = Spec for USA market built for sale in the US
H51 = A/C
WH23:
Dodge Charger
High
2 Door Hardtop
1973
Lynch Road, MI, USA
E44: 318 cid 2 barrel V8 230hp 318-2bbl 170 horse net.
D34: Light Duty Automatic Transmission Standard duty automatic transmission
S1Y4: Trim - Unknown, Unknown, Gold/Black Sport Trim Level; Cloth and vinyl bench seat; in medium gold color. Pics here: http://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1973/73_Charger0006.jpg and http://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1973/73_Charger0007.jpg
517: Build Date: May 17 Scheduled production date. Not necessarily the actual date assembled.
S04493 = Vehicle Order Number
Hope this helps
Nah they are easy once you know what you are looking at.
Geeze...nothing like a little pressure ;) and I'm far from an 'expert'. I, too, learned something from this tag.
Research continues.....
I have a question 69Coronetrt (sorry to hi jack). In the sequence number, does the 'C' mean anything? Production line number for instance, or is it just part of the sequence number? Its also a 1973 Dodge Charger built at St Louis plant. Just curious.
It's simply an internal station number. There were various "stations" throughout the plant where sub assemblies were put together for an individual car. "Stations" would include areas like dashes and interiors. That's why you'll find broadcast sheets attached to dashes or in the seats. The sheet generated at that station for that subassembly was attached or inserted into the assembly so people could match up the sub assembly with the correct car.
STL happened to use letters. I've seen sheets from the STL plant start with an A, B or C. Some plants, like Hamtramck, used numbers to identify stations.
I think it's pretty clear from the tag above that the 727 did come behind some 318's. It depends on the application.
Awesome, I learnt something there. Thank you very much.
Thank you so much guys! That really helps me to envision what the car would have been like from the factory.
