- 5:23 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Well, for the next few weeks or months, I'll be living here!
Finally after all this time, I'm at the point where I can make some headway on this car. Finished the engine build last week so that gave me the green light to yank out the original 361hp. I'm not going to disassemble anything until I have the replacement parts ready. If this was a rotisserie build, it might go a little different.
I decided to pull the engine and trans together. Man that's a tight fit and I won't be installing the new engine the same way. (Looks like I'm in the market for a trans stand/jack of somekind). I had to stop halfway, set the oil pan on the K frame and readjust the chains. Then the oil filter had to come off. Then the water pump was interfering with the hoist so I took it off, and that just made it. I've pulled the engine and trans together before but normally we were junking the car. I thought I was in trouble once or twice but we got her out.
Here's some pics for your viewing pleasure...
Rust! The radiator weights a ton!
Original fuel pump? Check out the push rod plug!
Over due for a valve cover gasket?
And frost plugs?
I took pictures as I disassembled, so if anyone needs pics to see how things come apart, with instructions, just pm me. Park cable, shifter cable, speedometer cable, e-brake cables, exhaust, wiring, ect. This is a 95% original, untouched 1962 Dodge Polara 500...
And frost plugs?
