Chrome carb fuel line
1968RRTEXAS
3:19 PM
Fort Hood, Texas
Is there a place to buy a pre bent fuel line that will reroute the fuel supply line from the mechanical fuel pump to the back of the engine. I just got my new chrome fuel supply line and the hose is touching the distributor. I'm not comfortable with electricity and fuel being that close.
This doesn't answer your question, but without getting technical, I think you are worrying needlessly.
You are correct that it's better to have fuel flowing UNDER a potential spark source than over it. However, my car is set up that way...no leak, no problem... but I do keep an extra close eye on that connection.
To get more clearance, you could turn the distributor clockwise & "leap-frog" the plug wires over clockwise too a couple spots to move the vacuum can a little out of the way. That gives you some clearance to attach a rubber fuel line to the end of your carb's upper fuel line dual-feed setup. To be even more safe, many of the dual-feed upper fuel line setups (not the one you have I don't think) have fuel inlet nipples that screw in. If you remove that nipple/hose barb, you could plumb in some custom-bent hard metal fuel line (less prone to leaks). A last option would be to turn the upper dual feed fuel line backwards (which I think is what you're asking about) so the fuel comes in from the back of the engine.
For all of those options, from what I know anyway, nobody makes anything "pre-bent" to bolt up, but using a tube bender and/or flaring tool isn't too tough, so why don't you just make up some custom metal fuel line for that section?
I could make some metal fuel line. But the cost of buying a tube bender and flaring tool would be higher than ordering a pre fab one.
I had the same problem with my Holley and changed to a stainless braided assembly that was much shorter. Several suppliers offer them such as Summits' #SUM-220106___ or look at page 24 in their latest catalog.
I know Inline Tube make brake lines, but maybe they can do custom work on your fuel line.
I've experienced the same issue with Holleys on stock 440 intakes. My answer was simple - gently bend the fuel line to gain more clearance under the distributor.
It will bend - you just need to be careful not to get nuts with it to the point you crimp the line shut - but it will take a little more effort than you think it would.
I've done this with the fuel line firmly installed in the inlets of the carb to hold it still (here come the comments telling me that was foolish, but...) and using one of those hammers that's full of shot ("dead blow" hammer).
Well. I bought some 3/8" fuel line for $10. Got a tube bender. Then line is double flared and has the nut already on it. So I don't need a flaring tool. So I turned it around and it looks great. Except the fuel pressure gauge is now face down.
Looks good. Is it possible to drill and tap the other side for the gauge and then plug or cap where the gauge is now.
The fuel line came with a plug where the gauge is now. That's a good idea. Thank you. I just reversed it back so I could get it running. It's going to have to go on my to do list.
I know you bought flared tubes. If you decide to buy a flaring tool, make sure you buy one with the right angle. There are at least 2 standards (I think 45 degrees and 37 degrees) and they will not mix and match without leaking. I learned about this the hard way.
