How's the Charger coming along?
Things have slowed down for now. Seems like every week we have been gone to one thing or another, then I have to catch up on work. We also have been enjoying some vacation time riding horses in the mountains and fishing.How's the Charger coming along?
Thank you GTX for answering for me. I was gone fly fishing up in Idaho on the St. Joe river and just got back. I think that it will be a good power steering unit.Oh and coupler for column. Not a big deal.
Thank you for your tips. I was able to check everything you suggested before installing, it helps. My steering column is only temporarily installed in the car but I did remove my headers before trying to install the engine. I remember that you were able to install yours from the top so I should be able to. I will probably put on my old cast iron ones when I brake in the engine so that I don't over heat my headers and discolor them.I found the same thing on my pitman. Is the steering column in car? If not you can install the starter (if it's a mini) after headers are on. It will help if cables are on starter also before install. I dropped mine in from top so not sure if engine will install from bottom with headers on. Make sure to put 1 quart of ATF in the convertor before installing. If oil sending unit isn't in it would be easier now.
