I mentioned several posts ago that the engine was experiencing temp creep in stop-n-go traffic.  Last Monday when I drove the car home from the tranny shop it was over 100* and the temp stayed at 185* the entire time on the freeway.  In the 10 minutes from the freeway to my house, with light traffic, climbed to 197* as I was parking in the garage.
This weekend I installed a new fan with thermal clutch. Don't know what make of car the fan was from, just know that it fit. (Hawk - once again, Randy to the rescue with his 30+ years stash of parts).  Idled the engine in the garage, over 100*, with a t-shirt in front of the radiator to block air flow.  It took over 20 minutes to get to 205*; removed the shirt and the temp dropped to 195* within a couple of minutes.  Let it sit for about 10 minutes, fired it up and it idled at 186* for another several minutes before shutting her down.  I believe the problem is solved!  Besides the added clutch, this fan is 18 1/2" vs. 18" for the Mopar; fan blade tips come within 1/2" of the shroud.
Original Mopar fan on the right; 5 bladed fan from unknown source on the left
A little more than 1/2" clearance on top; less than 1/2" at the bottom. Engine is angled slightly.
The say if the fan can hold a paper towel against the radiator then you've got good airflow.  This setup is holding up a Mopar Muscle mag in front of the a/c condenser and rad.  Good enough!
