Paint opinions for 66 charger
Too many unanswered questions in the OP.
What color to paint your car is not necessarily just a question of what you like best. Well, maybe.
But:
1. Are you painting it yourself?
2. If not what are you willing to spend on prep.
3. If you are painting it what amount of your time are you going to spend on the prep.
4. What is the condition of the body?
5. Flaws will show up more with a dark color than a light color and will require much more body work to make it look like anything.
6. What type paint are you going to use? That is a factor.
7. This body is very complex. Dark colors will not show up the body lines and facets as well as a light color with shadows that highlight them . Look.
8. Is your car A/C. A dark color will make a difference if it is not A/C.
I drive A bodies of different colors and can tell you it does make a difference on hot days in the south. (Iowa? Eh not so much, maybe)
9. A light color will be harder to keep clean. I like brown shades for daily drives. Dirt does not show.
10. Are you going to paint the engine bay body color? A light color will show dirt. Try keeping it clean with Y3. It's a battle.
11. I'm sure that you are going to paint the trunk body color. Good.
12. And just to make an even dozen, I want to emphasize how HARD this body is to do. I fought this one. And it was fairly straight to begin with.The lines are straight. But the paint could still use some finishing work.
In all of the above I speak from years of experience.. It is not theoretical but it is, ultimately, your choice.
I strongly suggest the KISS rule.
Unless money or time isn't an object. In that case, never mind.
I need to add that the cowls are a ticking time bomb on all these old cars.
Yes, even Mustangs.
If you are going to do this, I would check it first thing. Use a boroscope if you have to.
But:
1. Are you painting it yourself? No dont have the shop or experience...
2. If not what are you willing to spend on prep. What prep are you talking about?
4. What is the condition of the body? Body is in great shape from California one rust spot by the rear window where the drip rail runs water down that window.
5. Flaws will show up more with a dark color than a light color and will require much more body work to make it look like anything. I think I am sold on a two tone... Just to make it a little different. Its not an original car anyways and I've always wanted a dark blue color like Azurite Black... I think its sharp.
6. What type paint are you going to use? That is a factor. Im not sure what paint my body shop uses Dupont ? IDK though...
7. This body is very complex. Dark colors will not show up the body lines and facets as well as a light color with shadows that highlight them . Look. I could see how dark colors wont show the lines as much... thats the only down fall I am trading back and forth.
I drive A bodies of different colors and can tell you it does make a difference on hot days in the south. (Iowa? Eh not so much, maybe) I do have A/C so not a worry. If two tone would dark blue on bottom and a darker gray on top look ok?
9. A light color will be harder to keep clean. I like brown shades for daily drives. Dirt does not show. I do plan on driving it during good weather so ya Ill be washing it some haha.
10. Are you going to paint the engine bay body color? A light color will show dirt. Try keeping it clean with Y3. It's a battle. Y3? hmm never heard of it. Engine bay is already a dark blue metallic color I did myself. But not a problem my guy said he can redo that no problem to match what the actual color is.
11. I'm sure that you are going to paint the trunk body color. Good. I dont understand the question sorry...
12. And just to make an even dozen, I want to emphasize how HARD this body is to do. I fought this one. And it was fairly straight to begin with.The lines are straight. But the paint could still use some finishing work. There are a lot of awesome body lines to this car and I cant wait to get it painted, still not sold on color. Its getting frustrating haha get it in next weekend to start the body work and prep..
I strongly suggest the KISS rule. KISS RULE?
Unless money or time isn't an object. In that case, never mind. Ha Money is a factor I found one guy to paint my car for my figure I wanted to spend.
I need to add that the cowls are a ticking time bomb on all these old cars. Cowls? not sure what u mean by this?
Yes, even Mustangs.
View attachment 354038 View attachment 354040
But:
Body prep. I think this relates to Numbers 3 and 4.
Still, much work can be done "blocking" a car even if the body is in "great shape".
You might be surprised how many flaws show up once you get shinny paint on a car if blocking isn't done. I live with some flaws because all of my cars are "drivers" not show cars. Want to know why some paint jobs cost so much? Hours spent in prepping. What are you willing to live with? Remember this car has lots of facets and can be a real pain.
Two tone is fine but I think you are in the minority. Are you going to ever sell the car?
Just saying as they say.
I was thinking more along the lines of single stage or two part paint.
My only experience is with single stage. No clear coat. If you aren't going to paint it yourself this is less and less important. I know I can touch up my single stage if I want to.
Y3 is a yellow. Chrysler painted the engine and trunk body color to respond to number 11.
Keep it simple.
Cowls rust out. I just threw that in there since I had to replace the cowl top on a car. It would be a shame to spend money on a paint job and then find out your feet are getting wet. Some people pull the heater box and do a cleanout inspection during restoration. Cali car probably is OK.
Yes, even Mustangs.
View attachment 354038View attachment 354040
