XMAN JR
Lets hear about those 383 strokers out there. HP, compression, heads. intake, CI. ect. What combo do you have ?
this '65 is one of the nicest i've ever seen!My 449 ci is a .030 over 383 with an Eagle 3.9 in stroke crank, Eagle H beam rods, J&E forged pistons, Edelbrock heads. Compression figures out to 9.9 to 1. Comp xe274 cam, Edelbrock perfomer rpm manifold, Edelbrock 800 carb. Backed up with a Tremec TKO 600 and 3:55 8 3/4. Pulls like Jack the Bear from idle on up with 91 octane, pretty happy with it. And it all fits under the hood of my 65 Belvedere.
Thank you Mr. Tot, that's quite a compliment coming from you as your 2 Dodges are as nice as I've ever seen. Haven't seen you in a while, hope your doing well.this '65 is one of the nicest i've ever seen!
MMM just like the engine Im gona have built. It will be in a low 3000 lb barracuda. Hope to see mid to low 11s383 into 496", Stealth ported heads, Muscle Motors B rod combo, Comp custom solid flat tappet, RPM intake, TTI headers. Dynos (chassis) around 580hp, 600tq, 10.4:1 static, tight quench, runs pump 91, pulls past 6K. Built two years ago, IIRC it has about 19K miles on it, runs 117 in the quarter in a 3900lbs E body. He drives it like a rental. It's stock block, stock caps with main studs, stock oil pickup, minor oil passage mods, std volume pump. Bigger heads and camshaft in the works for next year.
