OH71RRunner
Guess what? I need help AGAIN......
I started chasing some overheating issues a while back. Biggest help was finding a false reading due to temp gauge wiring. It still was high tho. I did all the typical stuff: thermostat, coolant change, checked radiator hoses, and as suggested, timing. Timing didn't look right. It bounced all over the place. It wouldn't stay where it was supposed to be.
Bought a new pro billet msd distributor. From the different threads I had read, changed springs to one silver, one blue. And changed bushing to the black one. New plug wires installed. Plugs looked good. But will replace those later this week too.
Checked for TDC. Mark on the damper lines up with 0 on the tab. Plug wires checked for correct order and rotor positioned to #1 plug wire on cap.
Engine started fine. Tried to set initial timing to 10* BTDC. Runs like crap. It runs best at about 10*AFTER TDC. OK, tried to set total timing at 36* BTDC and forget about initial. No luck. Runs horrible. Set it to 0 and runs fine. Runs better about 5* AFTER TDC. Drive it with total of 36* and i get lots of pinging under load. Set it back to 0 total and runs better.
This is fairly close to what the other distributor was doing.
Have the MSD 6al and MSD Blaster 2.
Carbs were also checked and reset according to the 6 pack engine handbook. They seem to be working properly.
So, what am i doing wrong?
