looks rusty in the pic. maybe embarrassed !-LOLFound this yesterday.
The rod, the cap and the bots and nuts have a red hue.
The engine ran great and only has 60K original miles.View attachment 359167
Maybe pull that cap and look for scaring. It might have run hot...
Fixed it for you..unless you actually meant that the rod was scared? In which case I can see why it would be red.Maybe pull that cap and look for scarring. It might have run hot...
Have heard of that before and it makes sense. I also have some 'B' engine rods that are done that way...Big end was out of spec so it was dipped in copper from the factory and re honed.
In order for it to get discolored by overheating, the engine would have had to have been red hot (and probably would have seized) and all the others would look the same.Is that what normally happens if it's run hot?
