- 11:08 AM
- Jan 13, 2013
- Baldwin Park So. Cal.
I mounted one on my 66 satellite and mounted it wrong.... It should be mounted far enough forward from the rear of the hood to allow the bolts to clear inner brace. If its not placed in the correct position front to back the bolts will wind up inside the ribs and you won't be able to get the nuts on them... Double check this before you drill holes. I certainly didn't!!!!For those of you who own 6667 Coronet charger with this particular type of scoop should I mount it all the way back against the back edge the hood or should i mount it a few inches forward what do you think
Wagons are sick especially the 66-67 variety, Got any more pics from the side.....Compare with the six pak scoop.
Mike View attachment 378728
love the wagon ! the color , not so much .
Are your glass hoods designed to compensate for this or do you have to hole saw them too? Seems they should be molded to accept the scoop mounting hardware without cutting 1" holes in the braces of a brand new 500+ dollar hood. IMO looks silly...This is Larry at Sled City Fiberglass. Here is the final word as to where to place that R-O scoop on your 66-67 B body. It gets mounted at the rear edge of the hood, same as a 64-65. We race what we sell and that is where it is mounted. My friend at Smith Motorsports has a real R-O and a real W-O and they are mounted clear to the rear also. Your screws that are in a brace area needs to have a hole saw used there for a firm tightening surface. Oh, by the way, we sell all the fiberglass for your B-bodies including all the scoops, fenders, hoods, bumpers and trunks, and some dashes.
