 - 7:39 PM
 - Oct 16, 2014
 - Salisbury, Vermont
I see. That's funny that I never noticed that. Makes me want to cut off my quarters and stitch up some Charger ones on the Express.
			Yep, I have been eyeing that bulge too. I have tubed the wells to the frame rail but I don't like the bulge behind the quarter when it could just as easily go straight up and then over the top. I expect I'll be cutting those and modifying them soon. I want to use M/T Sportsman 29x15-15's and the section width is exactly 15 inches. That is about 1/4 inch from the frame rail and the same from the well lip. If I don't modify those bulges it will have to sit too high for my tastes, I want the stance lower. I think the bulge is there to push out against the quarter skin around the wheel well to keep it from warping. It's beginning to look like I might never be done with the metal work on the Express.Mine rubbed where that push in above rear wheel opening.
Did you have to jack springs down to get tire into wheel well. I have 11" drums and hemi springs and had to put a bottle jack to jack down the spring to get the tire in the well. ( I made a note of this in an earlier post and that I kept the bottle jack in trunk to change a flat.) I think your right about rubbing going around corner's mine did, and polished the wheel tub.
Be careful at first, those are awfully close on the outside.....
That does sit pretty high in the back though.
	Will 17x7 with 4. 25 backspacing fit on my 67 coronet? If so what is the largest tire I can comfortably run.
28x9 is from what I've read is the largest tire, but 235/50/17 adds up to 26.6x9.3. I'm so confused.
