Charger21
Ok so I have a 73 Charger 400 4bbl with 727 and 3.55 Suregrip gears and factory high performance 440 exhaust manifolds. I also have a bare 400 block sitting in the garage. Looking to start an engine build and not sure where to start.
I am shooting for something with around 400 to 450 horsepower on pump gas for street use only (no strip use). I know my engine is low on compression so pistons are likely in my future and I will likely need to upgrade the heads. I have access to extra 906s and 452s but not sure if I should just buy some aluminum heads or try to have the factory ones worked over.
Also need a cam obviously and have considered headers but not sure about the durability and common flange gasket issues.
Any thoughts on where to start? Should I look into a stroker kits from 440 source?
Thanks!
Thanks!
