ckessel
Good to go and I forgot that the lower arms have different sway bar tabs and the center link is different. Are you going to reinforce it before you install? If so, pm me your email and I'll show you what I did on mine,
Out of stockYour Gonna Need a New Trans Mount ! Lucky for you these guys Make it !
http://www.engine-swaps.com/Pages/ProductsYear/62.65bBody.html
That helps! Seems too many are.Out of stock![]()
If you are running a push button. A S10 mount on welded piece of angle cut 2x3 square tube works. Cheap and quick. Readily avaliable as well.
1.75" measurement was one of the other reasons I stayed with my stock k-frame, since as you know the later ones move everything back. And why I only needed 1/2".
But, betting you'll get it figured out!
Glenwood, my 64 was a 426 wedge car(street) the engine when I got it was about 4" from the firewall, was about to install a 440 when I noticed a crack in the K, replaced with a 67 gtx K, didn't notice untill we got ready to put the shifter in that the motor was back about 2 to 2.5" to the rear, WTF is this????(manual tranny is easier) had to move the shifter hump in the floor board back. 17 yrs later put in a auto, had to flatten the seam in the tunnel out in the engine bay to clear the 727 bell, but that was the only mods I did to the body to make the two trans work. I looked at the rear mount and decided that it was so narrow that it didn't matter, the tail shaft couldn't move anywhere, so I did not put any bolts in the rear mount. just think about this,I have owned the car since 1975, 383,440,440,426hemi,440,509, none have ever had bolts in the rear. I think that the 64 is the only one that this will work on as all the rear crossmembers I have seen in the last 40 yrs have been too wide to work like that. maybe just the big block cars, don't know. Dave.Just wondering if anyone has pics of their RB engine in a 63 or 64 that has a later K-frame in it. Wanted to see what spacing looks like behind the engine and around the steering box.
I saw a 68 k-frame with a sway bar for sale locally and was thinking about the swap.
I installed a Alterkation front suspension and welded the engine brackets to the K member (long story) so I was able to max out the reward setback. Had to cut the tunnel out and further back (GV OD clearance). I fabbed a new cross member and used the later OEM spool type mount. I already showed this to Doug but, I don't think anyone else has seen my setup.
View attachment 391425 View attachment 391426 View attachment 391427 View attachment 391428 View attachment 391429
