Thats a manual adjusterNo self adjuster, also?
If your drums are round, setting your shoes where there's no drag when things are hot isn't going to make any noticeable difference in your pedal. We're only talking about about a few thousands of an inch here and if you think about it, if they are dragging, you're creating heat and faster wear...."Cranky" is thinking the new way 'for better gas mileage'.. Who cares about brake drag? I'll go for high solid brake pedal anyday.. lol
View attachment 390689 View attachment 390690
The wheel cylinders you have are either incorrect or horribly manufactured. Read- cheap Chinese junk. Attached is a pic of a Bendix cyl, note the correct orientation/angle of bleed screw.
Replace them, my NAPA store sells them retail for $12 each. If these are junk, what else is?View attachment 391118
All it's for, is to find a starting point...I also like the idea of adjusting for brake lockup and then backing off. Probably centers up the shoes better in the drum. Next time, I'm going to try it. Makes sense,I think...
Also correct, I always do a visual check when picking them up and ALWAYS replace the bleeder with one I have. But then again I have a stash from an old service station pick from years ago.Also Chinese. The bleeder is thinner than stock and sometimes the threads are not very tight and easy to twist it off if you are not careful.
Sorry but that is wrong. You don't want any drag. They will heat up on you, then they will fade away while driving.Right, or wrong I adjusted for good pedal, which means I had more drag than what is considered 'correct'.
Don't agree on no counting...but not turns, but the clicks, or each adjuster tab against the spring. Count those clicks, backing off, then same thing on other side. Only reasonable way to get accurate adjustment, and equal both brakes on the same axle.No counting turns of the adjuster. It's a touchy feely thing!
This is a ultra base super stripper model PT Cruiser that is a 40K mile cream puff. My sister in law bought new in 2006.My daughter has an 03 PT GT Turbo. I hate that bastid! The wife wanted one when they first came out and when I opened the hood on one in the show room, it only took about 5 seconds to drop it and walk away. It pissed me off when my wife took the daughter out looking for her first car and came home with it because guess who ended up working on it.
