I do not agree. The pin should not have any slop, spec should be roughly .001". I hope you swapped the rod.It spun a rod bearing. Everything was fresh from the machine shop. We think the problem came from me putting the spiro-locks in the piston. After destroying the bearing, I took it to my machinist and he said that the spiro-locks are not correct for my application, didn't allow the wrist pin the slop it needed, and therefore the rod tried to walk on the crank and therefore spun a bearing.
I think you're misinterpreting what I meant to say. I mean the piston should be able to slide back and forth on the wrist pin. The pin itself isn't josseling around in the piston head or anything like that, but rather the piston is able to now slide on the wrist pin back and forth a little bit. I didn't swap the rod, I had it fixed at the shop.I do not agree. The pin should not have any slop, spec should be roughly .001". I hope you swapped the rod.
As a separate question, while installing the new rod bearings, one of the new ones had a slight nick in it (quote)
So it wasn't sloppy. The rod hadn't been pin fited properly. Then yes that would be an issue. Why only one rod? If there is no raised portion the nick itself won't bother anything.
What assembly lube are you using and how clean is the assembly area? Given the journal size, application and power level, I would prefer .0025 but .0020 will probably be sufficient.Update:
After taking out all the brand new rod bearings I had just put in a few days ago, almost half of them were scarred up. I'm not sure how this happened, maybe from smacking them too hard trying to get the caps off? I'm not sure. Regardless, I will now be getting all new rod bearings again. The mains were still good, and all checked out at about .0015in
When I did the clearances, I did it with no lube and as clean as I could get it. The crank may have had a thin layer of oil on it yet, but I doubt it. The area was clean to the best of my ability. After I did the clearances I took it all apart, lubed it all up and installed them. I'm using Sta-Lube assembly lube with moly-graphite.What assembly lube are you using and how clean is the assembly area? Given the journal size, application and power level, I would prefer .0025 but .0020 will probably be sufficient.
Is the line bore correct? Rod bore correct? If so .001 rod bearings are available. Also Clevite H series have more clearance than Clevite P series. What bearings do you have now?So what are my options to increase the clearance?
