Anyone use one. Looks like the solution for oil changes etc on the modern low slung Mopars.
http://www.quickjack.com/
Thanks. What I needed to know. The 06 Daytona and 09 Challenger don't want to go up the ramps, and I can't get the floor jack under. Do my own driveway/carport oil changes. Ramps slide or catch chin spoilers on both cars.We have one in our shop, not that brand we got ours from corn well tools, comes in handy does what it's supposed to do. I will say I can't get my SRT charger on there, id rip the bumper off, but I have it lowered, stock suspension it would probably fit.
Ya the ramps are about worthless with these cars. I used to drive my charger up onto a couple 2x4's or even used some old rotors I had laying around and then I could slide the jack under the front and lift from the k frameThanks. What I needed to know. The 06 Daytona and 09 Challenger don't want to go up the ramps, and I can't get the floor jack under. Do my own driveway/carport oil changes. Ramps slide or catch chin spoilers on both cars.
Is that center wishbone behind the motor? What's your jack point. I like the rope idea too.Ya the ramps are about worthless with these cars. I used to drive my charger up onto a couple 2x4's or even used some old rotors I had laying around and then I could slide the jack under the front and lift from the k frame
ya right in the center underneath the motor, set my jack stands up too obviously.Is that center wishbone behind the motor? What's your jack point. I like the rope idea too.
Never thought of thatif you want to keep your ramps from sliding, tie a length of rope to the end, long enough to reach the rear tires. When you go to drive up, the rear tires on the rope will keep the ramp from sliding. Just don't spin your tires, but this works pretty well.
Nice stance. Mine a highboy by comparison. The Daytona is lower.
I'm calling the HOA. Right now.Hmmm... this jack may be a solution on my not being able to work on my car because of the association rules. If this jack truely holds 3500 lbs (about the weight of the GTX) I may be able to use this in my garage and work on my car under the cover of darkness.....
I'm now taking all the calls for the HOA - Call me and I'll relay your concerns.....I'm calling the HOA. Right now.
