What front suspension to use on 1967 Satellite
Thanks - think I am too cause not sure if I want to run 17" inch rims or not - so going stock spindles
Yea I'm going to run 18's, so that will take up a good portion of the opening too.
18's what width and backspacing?, What size tires? - gotta figure out that too. So want to be sure they fit.
I'm gonna run the 18's on my 69 roadrunner. I have 295's 15x10's on there already so some 295's on 18x9.5's should clear no problem.
how long to get it,
Varies, he builds each one as an order comes in, so it depends on how many are placed when you do yours, my front kit took I think 4 weeks then another to powder coat, the rear kit took longer because I ordered it right after Mopar Nats and Carl was slammed with orders after the Nats. Both are exceptional quality. I went power rack, sway bar and 2 inch drop spindles.
yeah I am thinking the same thing - he quoted me 4200 - with 11" brakes not wilwood
Holy crap, that is a bunch of money!
yes, yes it is. But when i added up how much it was gonna cost me to re-do my dart suspension with just standard factory OEM stuff, the cost difference was just a couple hundred bucks. I ordered my kit from Gerst without brakes to save up front some. plus I picked mine up a show to save the shipping.
  1. Let me start off by saying a few things that may impact the way you value these opinions. I have no formal training in anything automotive related. All of my opinions are based on observations and experiences. I have read nearly every tech article written by Mopar Action magazines guru, Rick Ehrenberg. While I do not agree 100% with everything he says, in most cases he presents a well scienced arguement to support his opinions. He is not into aftermarket parts that are based on appearances. He is heavily biased towards durability and reliability. He has stated several times his opinions against the use of the non adjustable "Green" brand axle bearings for them being a poor replacemen tfor the excellent Timken tapered roller bearings. He has also expressed a lack of faith in any and all of the aftermarket front suspension kits that eliminate the torsion bars.
    I have been wrenching on these cars since 1982. Although I am a Carpenter by trade, I just love to tinker with these old cars. My first car was a 69 Dart. I wanted a 68-70 Charger but never tried that hard to find one. From 1984 to 1993 I didn't own any Mopars, I was a Chevy guy. I still thought of the day when I'd own a Charger. While being this Chevy guy, I thought of how if I did get one, I'd gut the stock torsion bar stuff and somehow graft in a Camaro style front subframe.
    I finally bought a Charger in 2000. I looked at the suspension and thought seriously about these radical modifications. I read from Rick E and a California Bay Area suspension guru Tom Condran. In their articles and books, I began to see the benefits from Ricks and Toms observations.
    The Mopar design really is a great example of engineering. The unit-body design is as well. The body serves as sheet metal reinforcements for the whole car with no weight penalty. All frame members are designed to share the suspension and steering loads. Each part was built to work together, no single member was designed to carry everything. The frame rails were designed to be strong enough to support the car without being too heavy. The torsion bar design allowed the suspension and steering loads to be spread out from the K member back to the lateral torsion bar anchor/crossmember. The design allowed weight to be placed lower and further to the rear as compared to Ford or GM cars of the same size. The lower control arm with strut rod made for stable suspension action with minimal deflection. The steering assembly was rear mounted to move weight rearward and to save weight and cost of a longer steering column.
    Rick Ehrenberg ran a stock body 69 Valiant against some impressive cars in several "One Lap of America" race events and did quite well. He wrote several articles on the car that he named "The Green Brick". These articles were important to me and set my course where I am now. His theme of stock based suspensions with a few improvements appealed to both my CHEAP style and my appreciation for engineering.
    In 2002, I took my 70 Charger and swapped in my first 440. I knew the stock 318 spec torsion bars would be too small so I ordered a set of 1.0 torsion bars and a set of KYB shocks. I wanted a bigger front sway bar but being the junkyard dog that I've been, I searched through the junkyards and found a bar that matched the contours of the stock 70-72 B body sway bar. This one came from a 73-87 Chevy 1 ton 2wd truck. All I had to do was shorten the ends and drill holes. For $40 I had a solid 1 1/4" front sway bar that fit. I rigged a rear sway bar from a Ford truck.
    For 4 years, the combo was pretty good. The ride seemed a bit stiff but it handled well on smooth roads. In 2006 I swapped in Addco front and rear sway bars, 1 1/8" front, 7/8" rear. I also changed the leafs to Mopar Performance 440/Hemi springs. The car was a little light in the rear on hard turns. It wanted to hang the tail out on sudden turns but the body roll was very slight. I was more concerned with some engine problems and home projects so I put the suspension on the back burner for awhile. In 2012 I made my own subframe connectors and torque boxes. They were welded in. The car handled about the same but it felt more solid on bumpy roads. It was as if the stiffer uni-body was now allowing the suspension to work rather than letting the car body deflect and absorb the bumps.
    In 2015 I made a few more changes that are still in place today. I took some tips from books that I have read. To reduce OVERsteer, you can increase roll stiffness in the front or reduce the stiffness in the back. I did both.
    I put in 1.15 torsion bars to add stiffness to the front. The 1 1/8" Addco front bar was removed and the GM 1 1/4" bar was put back in. I fitted an 82 Imperial 11/16" rear sway barto soften the rear. I also ditched the KYB shocks and went with Bilstein shocks. Now the car still stays flat in the turns but does so without the *** end wanting to get through the corner first. I still have urethane bushings in the strut rods and sway bar. The lower control arm bushings are rubber. The upper control arm bushings are the Moog K-7103 rubber that have offset centers to allow a greater range of adjustment for alignment.
    The tires are 275-40-18 front, 295-45-18 rear Nitto NT-01 with a 200 treadwear, far softer and stickier than most street tires.
    Steering box in a Firm Feel Stage 3 with he Fast Ratio idler and pitman arms. This puts the wheel at 2 3/4 turns from lock to lock, down from 3 1/2 stock. This makes the effort in the steering heavier and more deliberate. You dont get to steer the car with one finger!
    I love the way the car handles. It feels lighter in the turns than my 2015 Challenger R/T that is actually a nice handling car. The Charger weighs a shade over 4000 lbs as compared to the Challenger at 4200.
    The common theme I keep hearing from the guys that buy the aftermarket front suspensions is LIGHTER WEIGHT...Better EXHAUST CLEARANCE ! Lighter? At what cost? If you compare the stock setup with power steering against an aftermarket kit with a manual steering rack, then sure...NO arguement there. It might be even lighter manual steering versus manual....BUT the suspension load is now fully concentrated on frame rails that were NOT designed to carry all the weight. Remember, the beefy K member and torsion bar crossmember spread out the load in stock form. Some kits had lower control arms that look pretty but probably do not have the durability of the OEM stuff. If the car is driven easily and not on rough roads, you will probably be fine. If the goal is for better road race and autocross performance, take note that the respected Rick Ehrenberg, Tom Condran and Andy Finkbeiner have said that there is no clear benefit of these kits for race duty. Now...Exhaust clearance. Yes, with the stock rear steer stuff and torsion bars gone, there is a bunch of room there! To get it, you had to spend at least $5000. A well rebuilt stock suspension and steering will cost around half of that. TTI and Dougs make great headers that fit cars with torsion bars for $800 or less. These are my opinions but I have not just come to them on my own. I followed some trusted professionals to feel this way.
Kern Dog that's all well and good but you do realize this is a Forum dedicated specifically to restomods and pro-touring applications. The entire idea behind these builds is to step outside the norm do your own research and make decisions that lead you down that path.
A "resto-mod" or "Pro-touring" does not exclude stock based suspensions. I know that the bright shiny tubular stuff looks nice. I'm not against using something that looks better as long as it does it without stepping backwards in terms of durability.
& I'm accused of "paid by the word" :mad: ramble on & on & on :poke:
beating that same dead horse over & over again,
in every suspension type thread
To each their own opinions & you have some great & valid points too,
I can appreciate the other opinions & points of views too, thanks for sharing them
But;
this is the Resto-Mod & Pro-Touring forum section after all,
where IMO most projects veer from OEM stuff
not all kits or K-Members eliminate the torsion bars either
from someone who's actually used the stuff, 1st hand experiance &
not just commenting on the durability, longevity, handling, room or
even the weight savings, of said aftermarket parts or statements from others
it's only $$$, not all the aftermarket suspension pieces or
or aftermarket suspension kits are priced or made the same
some are outright affordable...
I've seen people spend thousand upon thousands on fancy shiny paintjobs
than just get cheap/price point shoppers when it comes to suspension,
aftermarket handling or lighter components, better brakes, Wheels & tires etc.
QA1 the ones I have has OE rubber bushing
& sway-bar attachments welded on, factory locations
in the lower Control Arms
just a lighter cleaner looking tubular arm, instead of stamped steel
SPC UCA's also have rubber/Poly bushed ends on the top too
lighter, not by much thou, way more adjustable than OE stuff,
actually adj. on the car too, both camber & caster
QA1 K-Members #52314 {IIRC} have OE style motor mounts too
{they claim 50#'s lighter, with their UCA's & LCA's}
the one I have I use a stock style steering mounts too
I have a Unisteer {Omni style rear-steer} rack & pinion,
I don't recommend, the rear steer rack & pinion steering
IMO defeats the purpose of having a tub. K member,
it takes away from the header & oil pan selections...
I had it before I bought the QA1 stuff,
the car went a different direction than I org. intended,
serious snowball effect... :soapbox:
IMO the Big brake kits really drive the pricing up,
multiples of thousands of $$$'s in some cases,
especially when you need specialty wheels etc. to accommodate them
so do the drop spindles, hundred more
so does the fact many use front steer rack & pinions
to open up the oil-pan & headers areas
I've used several of these the old Capps Automotive
& now QA1 stuff, I will install them on my current project too,
IMO very affordable, you can do one piece at a time if you chose to,
not all aftermarket stuff is the same
Night & day different from OE stuff, some is because of
ride height/lower center of gravity
some is because of weight bias too, better weight transfer &
some is because of so much alum. instead of cast iron in my engine bay
less tire wear, less brake wear, less shock wear, adds some to the longevity {?}
{I had about 12k-13k street miles & 100's of passes down the 1/4 mile,
on my last Silver 68 RR using these same parts, with no issues,
the new owner drives it daily, has over 25k on the set-up/combo I sold him
IMO much better power to weight ratios,
with all the tubular & alum, weight loss 100's of pounds in some cases
lighter pieces added, make for a much easier & many times cheaper
{seems to be an issue with some} than trying to make big HP streetable...
IMO Different strokes for different folks,
not everyone has the same views, experiances or let alone budgets...
To each their own too, some will never change their minds,
no matter what you tell them or say too...
Excellent piece of information - make allot of sense. I am surely thinking on what you have written. Great perspective!!
Thank you.
I am not trolling the likes of RMS, Hemi Denny, QA 1 or Magnum Force to try and sway me. I would even go ahead and admit that their systems do look nice. The owners seem to like them.
$1799 QA1 Stage 3 kit,
can't remember if it was Jegs or Summit Racing
