Hangernade
Hello all.
I've been trying to find some information regarding 727s. You know how internet searches go- too much information or not enough. I have searched here and gotten some helpful information but could still use some more.
I have a 73 Roadrunner with a big block and what the codes say is a standard duty 727. I've seen codes for light duty transmission and heavy duty transmission. As far as the hd trans goes, does that mean 4 pinion planetaries and possibly the 5 clutch pack? I think the hd designation may only refer to big block applications but can't say for sure either way.
I ask this because my car was having some trans issues the last time I had it out. I'm kind of swaying back and forth between a rebuild now, or swapping in another trans for now with a rebuild later. In searching for a trans I have been looking for the ones with 4 pinion planetaries and if it has the larger clutch pack all the better. I have a line on a 727 out of a Winnebago which I think has what I'm looking for in a trans. I have not seen it yet so I need to check it out before I buy it. I understand that it probably will have the short tail housing with the brake mounted to it.
As far as Winnebagos go, are there corresponding numbers to match the trans to the engine? They still have the 440 that came out of it, which is how I found the trans. Winnebago is a 1974.
As far as the hd internals, is there a way to confirm this without a teardown?
If it is a short tailshaft, can this be swapped out, or should I just be looking at this as a parts trans for the hd goodness?
