Lloyd Moore
Okay, someone smarter than myself help me out. I have a 67 Coronet and I hear a clunking sound whenever I make a right turn. No problem with left turn. I pulled the 742 case with 2:94 gears out and replaced it. I also had new bearings and seals installed. I jacked the car up with both wheels off the ground, seated the driver's side rear axle, and adjusted the end place on the passenger side rear. Once I got it all back together it started doing the same thing. There's nothing hitting against the undercarriage and the exhaust pipes are not rubbing. So, the question is, what's my problem? Thanks.
