1962 Gas Tank Removal
I had no drama with the ring supplied with tank (or was it the one that came with the sender?!)..
I believe I got one with both tank and sender. The lighter ring should work but the census says they haven't always supplied enough pressure.
Look at the picture of the rusted old sending unit. The rubber ring is laying there. There is only 1/16 to an 1/8 of noticeable contact that was made to seal that sending unit to the tank. Not much room for error.
I've always thought they work by some miracle...
So the fuel filter acts as the return back to the tank? If so, what regulates the fuel pressure?
The 1/4" nipple has a 0.060" restrictor built in and should be installed so 3rd nipple is the highest point in order to bleed off any vapor (gas). When there is no vapor, the fuel return flow isn't high enough to affect fuel pressure. I used a Carter elec pump that needs no extra regulator.
