Fun driver project : 69 Charger
I feel your pain about the body shop let down/rip-off. Been there done that. It put a black cloud over my progress also, but we must finish, we will finish! Chargers rule!!
P.S. Put those bottom rear corner pieces on as soon as you can while reworking that area to help with their fitment. They are sometimes hard to get right and that can help.
UFO spotted in belgium :rofl::lol:
Got somes news
new seats
and the bodyman got things done ! Happy, I'm ^^
Thoseare reusable
The trunk floor cut in half to get it out of the trunk, and weld ack together to install it properely without the quarters. Speaking about quarters
Everything looks solid underneat the quarters.
Thank you Elliot
Testing the new quarter from AMD. Looks good but it will need a lot of adjustement.
Thank you,
Elliot
Good luck with this project. I'm also restoring a 69 Charger. One question I have is how easy was the retrofit of the Mustang disk brakes to the Charger? I was considering something similar. Has to be much cheaper to convert than to buy all new ones.
:steering:
Got some news from the bodyshop !
Pretty straight car, isn't ?
The bolt pattern is the same, just have to build calipers brackets. I will do some template after approvement :)
thank you,
Elliot
Have a look at this thread. A guy over at DC.com makes brackets for front and rear.
http://www.dodgecharger.com/forum/index.php?topic=122780.0
I have both front and rear but so far only have the fronts installed. Works great with the 13.2" front discs (front).
It has been long since I gave the last news !
We added to arche to the jig
Anddd ... Way easier to weld underneat the car this way
Then we took the car to get it sandblast
My bodyman started to work on the front fender which was in really bad condition as you can see
then
Back from the blasting
The weldings Begins !! ! Starting with the driver rocker
Since I want to get 295 or 305 tires we minitub it (1 inch)
And with a 295 tires ! The frame rails will touch the ground before the tires touch the tub !
Final Welds
It looks realllly GOOD !!
Very nice work. Looks like you picked a very capable bodyman. Not sure if I missed it, but what color combo are you going with?
Thank you !
Yes my bodyman is a great friends of mine with a lot of talent and very young too (25) !
The car will be B5 blue from 2015 Challenger (still B5 isn't ?) with a white bumblebee-R/T stripe. No vinyle top. Going for a prodaily car slammed on the ground
Nice work on the inner rear fenders, planning on doing something similar but without removing the rear quarter..
