Cam and Head Combo Question
SgtLee511
5:59 AM
NE TEXAS
I have a rebuilt 69 383 to 69 specs, on the stand. I purchased Hughes SEH2428BL Hydraulic at the time I built the short block, already installed. My question is simple any problems using 906's ported/polished with 2.14 intakes and the larger 1.80 exhaust. Heads Im buying are already set up this way. Is this set up going to help me or hinder me,
http://www.hughesengines.com/Index/...b3cgRGVjayk=&level1=Q2Ftc2hhZnQ=&partid=30254
IMO the 906 heads with the 2.14/1.81 valve combination will work very well, the stock heads respond to porting & bigger valves. The cam should be great with ported heads, fairly high lift & fairly short duration. Good for a small displacement motor.
Thank You
