Doug Larsson
- 5:55 AM
- Apr 18, 2016
How do you adjust the choke spring it's a coil ?next cold start remove air cleaner and have someone start car
the choke pull off should open choke a little if to rich adjust
if starts to run rich after a short time grab manifold where the choke spring is if hot adjust choke spring
if cold check heat riser or cross over
I took a picture after adjusting the choke like it said on the paper i had for the carburetor. This is what it looked like on cold start and when it warmed up. In the first pic its in farther when cold the when warmed up it went out some.Post a pic of choke spring as there is a couple of different ones
The one you may have can be adjitusted with a screw driver
Is the cross over clear and does the heat riser work
I don't know what those terms mean can you tell me what they are and where to look. Thank youThat sounds right
but have you checked heat riser and cross over
The electric part is to help with cold emissions
The heat riser should be closed when cold and open when hot
grap it and it should turn 1/4 turn and spring back when cold
then check crossover heat
