rear cargo carpet install 66 charger question
Carney10
7:48 PM
Illinois
How do you attach the carpet to the cargo door (wood)? it doesn't appear there has been glue on the wood and when I removed the torn carpet it didn't seem to be glued. If you have replaces the carpet on this area what did you do? just use the tri to hold it in place or use adhesive? TIA
Glue it down with contact adhesive, get a gallon from an upholstery supplier and spray it out of a cheap paint gun. The chrome trim and hinge will keep the edges secured, but if you don't glue it down, it will sag and look fugly. I glue the carpet to the floor also....same effect.
