What carb spacer with Carter Comp carb?
6290988
11:40 AM
Raleigh, NC
Should I go aluminum or plastic? What brand was best? Is the edelbrock $35 one as good as the $100 ones other brands offer?
Good deal, thanks. I didn't think you should have to spend that much on one. It didn't make sense.
Also, why wouldn't aluminum do much? I thought aluminum helped reduce heat.
Aluminum is an excellent conductor of heat. It does also dissipate heat very well too but, a constant heat source (combustion chambers) in traffic with an aluminum spacer between your intake and carb will do very little. Ask me how I know.
Phenolic material is what PCB's were once manufactured on and dissipate heat like pretty much nothing else.
Take a look at this product. He was at mopar Carlisle, I bought a few for my 440 cars, but haven't actually tried them out yet. Different product, made very well, he had a bunch of literature guaranteeing drops in temperature
http://www.coolcarb.com/order-products.html
I see it warns not to use with any intake with exhaust cross over - or a cast iron intake, for that matter. Bummer.
I use a phenolic spacer under the Edelbrock 1407 here on my 440. Stock intake.
I did it to get clearance for the linkages/pivot points on aftermarket carbs (especially Holleys), which typically bottom out on the choke well on the stock intake.
Heat insulation is a nice by-product.
Now if someone could tell me how to stop this dang carb from losing all the gas in the bowls when the car sits a couple days....
I have the stock cast iron 4 barrel intake with a Carter comp carb.
I've noticed some of the Phenolic ones also say "Not for street use". A couple reviews say the spacer warped or crushed but the manufactures say it's "drag race only".
I decided to try the edelbrock one for as cheap as it is. $35, it comes with new studs and two gaskets.
For those of you that used a spacer with a stock intake did you have to adjust the linkage or mess with any of that. I don't see how an inch would cause many issues.
Have a 1/2" phenolic on my stock AVS & works great with stock manifold. The way to stop gas evap is time travel back to the 60's when gas was gas and proud of it. Lol
Didn't have to change anything in my case. The spacer got the carb linkage/swivel clear of the heat sink for the choke on the stock intake and I just hooked up and adjusted the throttle cable as usual.
With the phenolic spacer it is hollow in between the exterior and interior walls. Does the open hollow side face up or down?
If it isn't embossed or the instructions don't read specifically which side is up, my guess would be it makes no difference.
