- 8:36 AM
- May 14, 2011
- On the Ridge, TN
Thanks for checking in, KD. Always a pleasure.That 284 cam is sort of an oddball. It should make more power than the 280/474 and less than the 509 but my experience was that it idled as bad as the 509 with less power.
The 284 and 292/509 really like lots of initial timing. I ran 17 initial and 31 total (Instead of a more common 35 degrees) because at almost 11 to 1 it wanted to rattle at anything over half throttle. The MP distributor has an adjustable plate to widen or narrow the advance range. It is possible to run it tighter than I did if needed.
The Edelbrock is not the easiest to tune as compared to Holleys or the Holley based Demon/Proform, etc carbs.
As stated, vacuum advance should be only in effect at part throttle. If the vacuum line is connected to manifold vacuum, it puts the vacuum advance in from idle on up. That is not the correct use of the vacuum advance and will contribute to an unstable idle, especially with a lumpy camshaft. Think about it...The engine is running with loads of timing at idle, you lean on the gas a bit then floor it and half of the timing backs off. That is not going to give the best performance. It is better to set the initial and total advance THEN use the vacuum advance (Connected to a PORTED source) to improve mileage.
This one actually runs really nice at idle and smoothly all the way up through the RPMS - I've got some videos up on YouTube of it under this same name if you'd like to see it in action.
As stated before, I have the vacuum disconnected at the moment, figured I'd do that tweaking after I had the carb dialed in and such since it doesn't matter on much except part-throttle fuel economy.
Yes, I agree it should be connected to ported vacuum, as the FSM states.
The FSM also gives a procedure on how to adjust the vacuum advance with a 3/32" allen - if the car is jittery/surges under part throttle, adjust the vacuum counter-clockwise in small increments until you've dialed out the jitterbugs.
I'll fool with that once this other stuff is settled.
Thanks!
