pulling my six
67belvedere/225
2:00 AM
montreal
I m glad I found a forged crank from a later year slant six for 50$ . the machine shop is turning it down. now will be able to put my high stall torque converter with lock up
should be getting the crank back tomorrow
looks like Saturday is engine day
Your doing this just to swap in a forged crank? Love the Weber setup!
I'm in the same boat as you. Gathering parts for a /6 B body. I have a 71 904 trans and converter that is the 68-up with the bigger snout.It seems every slant I come across is a 67-older with the small crank register. I'll find one someday as my Gasser Slant is low on the totem pole.
no I am swapping early version of crank (until 67) the later version of crank end of it where the torque converter goes is larger to accept the lock up high stall torque from the 82 dodge diplomat tranny, on the six the block was changed in 76 when they went to a smaller nodular cast crank
I was lucky I went on ebay one day and some guy just had put it for sale for 50 $ I had it shipped to Vermont and drove down on the weekend to pick it up at the cottage , I m so lucky
Need to do some suspension and exhaust work and she'll be just about perfect.
I hope you go with 2-1/4" pipes? Looks like you got split headers and a 4 bbl on there, nice! Mine's stock except for the super 6 and a Weber 32/26 on it, nuthin fancy on my BamBam. See my tagline below!
They don't go fast, they just go!
There are some fast ones out there.This one with no power adders would run 12 .90's, all motor,no juice or blow .A friend of mine has his in the low 11's all motor in a 68 Valiant. You can make em' go !
