- 11:02 AM
- Dec 25, 2011
- White Cloud, MI
Steve, I'm using a 4"x16" filter so I cut a 19" circle out of the skin and a 22" out of the reinforcement. I will build a cylindrical aluminum air box to seal to the hood so I feed all fresh air to the engine. Thanks!Mike, Nice work on your hood scoop. I especially like the front edge. The 1964 Dodge is much easier with the inner bracing the way they are. I didn't have to cut any of it out, and with the air box I used and the "butt ugly" hood scoop, it finally worked out pretty well in the end. I am using the flat base ( offset cause the engine is not centered in the hood) on the air cleaner so that it's easier to get to carb adjustments I did have to go from a 2" phenolic carb spacer to a 1" to make room for the air intake hoses. BTW check out Spectre flexible duct plastic like hose that uses "threaded" on connectors . A little pricey , but well worth the trouble it saves. Easy to form and re-form and hold its shape. I will attempt to attach a pic...Good Luck !......................MO
