I am not really keen on removing the window now actually...scared
As far as the dash goes, i already did the rally cluster and everything is 100%. (Just external need some touch ups)
I will remove it anyway, together with everything else that can be unbolted.
Also the heater box will come out obviously, that way i hope i will end up with a bare dash frame.
That way i can clean up and slap the fire wall and dash frame in the POR 15 as well.
I already have a new dash pad (upper) to be installed and i will have to get a new dash wiring harness also.
This one is cut up too much and already have some electrical gremlins flying around there.
For the front window, i am thinking of removing this whenever the exterior of the car needs to be done, or if i want to...whatever comes first.
It's nice being Sublime Green, but from all i found this car originally was R6 red, which maybe one day it will be again.
You had some project as well on your car, still need to read all but just jumped forward to see the results
That car came out really nice!
And i've got the second coat of POR 15 in, that stuff dries faster then i was expecting.
I checked the section where i started expecting it still to be wet as it is so shiny, but instead is was already "tacky" so had bottoms up my fresh cup of coffee and get started.
Tomorrow's plan is to weld the crack, get the seams filled with sealant and once dry get the top coat of POR 15 in.
