1967coronet440
Any of you guys have experience with the mahle 4032 pistons? That's what we used for this engine, I haven't heard of these being used as much as say the diamond or Ross pistons.
So I just got off the phone with the builder and apparently he used the 4.5" eagle crank and not the 4.25" like I thought so I have a 535" here not a 505"
Sweet
No doubt, I thought he told me before we were going with the 505 kit but I guess notbonus!![]()
Always intended to build a run stand but never got around to it. Started many on the floor hooked to a chain fall. With blocking under a stock pan and headers/mufflers for outriggers and just enough tension on the chain to make sure it wasn't going anywhere it would sit and do fine......but just couldn't rev em much because they WILL climb that chain if you try to rev it much! Ask me how I know that! A stock 383 went 90 degrees up the chain and then went 45 the other way before it settled down when I no longer had control of the throttle. That was the first time to fire up a big block on the floor. A 318 or a 289 will sit there all day long and let you do whatever you want with it because they have no torque and figured a big block would do the same. Wrong lolThanks Justin, I actually have the frame of a homemade run stand a guy gave me years ago when I bought my old 440 from him, I'd like to get it set up and do it that way.
When I was racing my 66 Belvedere 'slocar' I got run off from the track right after the burnout box (I drove around it) because the starter saw water dripping from the car. I forgot to turn off the AC! Now this car was pretty much stripped down in the interior and only weighed 2950 and everyone thought it needed a roll cage etc but it only had a /6 in it and everything still worked. It was registered too and was my work car but it ran the number each and every pass!Was in the staging lanes on the weekend. A fellow that lost to me earlier was standing in front of my car so I honked and startled him. He was like "WTF is with the horns on that thing for", then I turned on my wipers.. lol. Ouch.
Thanks buddy, you guys are more than welcome to come on back by the garage once we get it fired it up.let me know when you want to sell hopefully at same price of your 70 440 lol just kidding looks great
Sweet
Yes a welcomed surprise! Nope they're out of the box, gonna run them are how we like them and revisit port work laterThat's got to be a surprize! Wondering are those MW heads you have out of the box or was there some work done to them?
Put on a 5.25" billet crank pulley from 440 source and polished pump and housing today
Thanks I'll check it out, I have to order a bolt kit for the water pump pulley and shim kit anyway.440 Source has some very nice aluminum deck rails for the valley plate and aluminum distributor hold down too. Would be very fitting on that pretty stroker.
Agree !! I thought the same thing but !!!, on the dyno rockers hit the covers, IDK but he had custom covers made@ $400.00Hmmm interesting, I imagine the builder checked for clearance.
Where was the clearance issue? On the sides, because I peaked in there and that's the only place I can maybe see an issueAgree !! I thought the same thing but !!!, on the dyno rockers hit the covers, IDK but he had custom covers made@ $400.00
I have 1.6 rockers also but they are t&dI've got Indy valve covers on my MW heads. No contact issues. Although I have Hughes rockers 1.6's.
