To each his own. Whatever floats your boat. My car is numbers matching, as in the VIN matches the registration and thats all I care about.
			I am no expert but from what I have read it was 69 and up for the VIN on the block ect. Maybe some late production 68 Bs had it, just to add to the confusion. Mine is not only Non NOM but a 440 as well. For me not driving it = no fun. If I had my dream car 70 Hemi Charger it would get lots of miles and rear tires. When I hit the LOTTO of course. Staying Positive...I read an article just three days ago about numbers matching. From what it said, from 67 back, there were no numbers on the motor or trans that matched the numbers on the body panels. If you wanted to know if your 440 was original you could not state it was for sure. Best you could do is to see if the date code on the block was before the date the car went down the line and then it is said that Mopar would make blocks ahead of time with a future date on it and on occasion an engine with that date would make it to a line ahead of the assembly date. (sound suspicious but that is what the writer said that Chrysler factory told him). So, my vote would be that matching numbers is beneficial in selling a Mopar post '67, but from there back, the only numbers that are supposed to match are the body numbers. Can anyone support this, or, refute it? Not sure if the trans matched the engine, I doubt it if the match between the engine and body is not there. I'll see if I can find that article.
Absolutely not true. The last 6 digits of the VIN which are the sequence (serial) number are on the block at least as far back as 1966 (probably much earlier). I'm not certain about the body panels, but the engine can be verified that it matched the VIN on the car.
On my 1968 Road Runner with November 1967 build date, the last 6 digits of my VIN are stamped on the engine block and 727 at the top portion of the bell housing where it mates to the block - on both.
Lots of folks make up all kind of stories when they are downplaying the value of an original numbers matching car.
How did you know the slant was original?Mine was....but it was a /6 automatic car with factory AC which isn't real common for a 66 Belvedere I.
When the car was purchased, it had ALL of the original paper work in it including the window sticker and receipts for everything that was done to the car. Had no idea all that stuff was in it when I bought it plus when I took it apart, there was no evidence of an engine swap or trans swap. However, it did have many coats of paint on it....How did you know the slant was original?
Yes they were supposed to start then. Some had them before...some started later....it's a variation from plant to plant,,,line too line. You guys can argue til your blue in the face and there is more than one right answer.i believe after jan 1st 1968 everything had to have an mvin stamped on the block. I think it was a federal law. there was a bunch of federal laws that went into effect jan 1st '68.
