There was no playing with anything in the format they had. Three consecutive pulls with no changes in between. All pulls were made in high gear.Did y'all play with the timing, jetting etc? And even if the stall is on the low side, I would think the engine would still pull through it once isn't slipping anymore. I mean, what would they say if the car had a stick in it?? I would hope the trans would be in high gear by 5500 anyways.
After everything cooled down I pulled all the plugs to see if I was down a cylinder and they all looked ok from what I could see. A little rich maybe but not horrible (see picture below). I really don't understand the numbers at all because everything is so far off. Besides the torque being early and low, the curve was nowhere near as flat as it should be. The converter was just built for this combo by Lenny at Ultimate with all the specs for the motor known ahead of time so based on his reputation I wouldn't think it would be that far off. We spec'd the converter for a 3800-4000 stall so it seems a little suspicious that this is where the dyno stops showing any additional gains. I'll call Lenny on Monday and see what he thinks. At this point I think I am just going to assume the test was completely bogus since I don't have any other indicators that something else is wrong. I'll run a leakdown test to be sure.It almost seems like you're down a cylinder. Car should easily make 500rwhp on its worst day, even on a mustang dyno. Graph seems accurate, spread is correct between peaks. I'm just surprised the torque peak is so low (which is why the results are disappointing), even with 526ci, should be at least 750-1000 rpm higher (I would imagine). 380 cfm of airflow @ .700 lift, something is SERIOUSLY wrong here for it to have a torque peak @ 4100 rpm with max-wedge port heads. Converter seems way off for this combination.
They did not but I don't think that is likely. If anything, reading the plugs it looks like the midrange might be a little lean.hard to read that chart. Did they hook up the exhaust O2 and graph the output.
I have seen some dyno pulls where the fuel mixture was way off and varied alot through the RPM range.
One guy with a Oldsmobile (Edelbrock heads and mechanical fuel pump) had an issue with this carb float. At idle/low RPM everything seemed fine, at high RPM fuel was coming out of the fuel bowl. As I recall, dyno curve looked good to about 3,000 RPM and then nose dived when the extra fuel made the mixture super rich. Lucky no fire from all the fuel.
What I meant by the high gear remark is that even with a stick, you're going to be in high gear....1 to 1 total lockup so imo, the converter shouldn't matter that much once the engine is up in the rpm range. Now if the converter keeps on slipping throughout the pull, then you need a better converter and may be part of the reason for soft numbers. Yeah, most will slip some but not enough to change the numbers that much. My dyno was the drag strip so I might be talking through my butt but even on the track, you knew if the converter was doing it's job or not and I would think you or the dyno operator would also know during a pull. At least the math could be figured out. On an engine dyno, you're not going to use a torque converter. To me, even a stock converter with total lockup behind a healthy high performance engine isn't going to rob peak horsepower/torque numbers, however, it will hurt you on the launch at the track. On a chassis dyno, a near stock or slipping converter will generally show lousy numbers down low until the engine gets up into it's range and then it will/should overcome a low stall speed converter and post good numbers....IF the converter is good. I've run plenty of cars with healthy engines with near stock converters because they were going to be daily drivers. They were pretty slow off the line but made up for it once the engine got into it's power band.....kinda like a 2 stroke dirt bike does.There was no playing with anything in the format they had. Three consecutive pulls with no changes in between. All pulls were made in high gear.
I am THE BELIEVER in 1050 Dominators for 500"+ Mopar BB motors. I had an 850 Mighty Demon on my Edelbrock Single Plane Intake and went 10.98, then all I did was bolt on a 4150 to 4500 Adapter onto my 4150 Edelbrock Single Plane. Same day, same track, only an hour apart....With the 850 Mighty Demon it went 10.98 then after bolting on the 1050 Dom it went 10.63 all day long in the low, low 10.60s. Over 3/10 of a second...need I say more.Card reads 526HP at 6,000 and 487 Ft/lbs at 5350 ..........That engine needs a MUCH larger carb......
Larger carb will bring torque peak up and make HP a much flatter curve...
Car runs 10.50 at 129 mph and is also street legal.. I do run an 8 3/4
noDJ, would smaller jets decrease the cfm on the 660's? (Sorry I don't mean to hijack thread here).
