Under Pressure
khryslerkid
2:41 AM
Hanover, Pennslyvania
Has anyone experienced the cooling system building up pressure all on its own?
I'm useing a "Water Wetter" type of additive called "Cool It" and distilled water. When I first started the engine for break-in, the water became stained but since then it has cleared up nicely.
After running the car, the last time, I noticed pressure in the system and that's normal. I released the pressure and noticed a couple of days later it built up considerable pressure again. So I released the pressure again. A couple of days later it has built up again? I haven't started the car for over a week and it still does this. I'm thinking there's a chemical reaction taking place. The additive did make a difference in cleaning up the stained water after the initial fire up so maybe that's what's taking place? I'm going to find one of those red leaver, release radiator caps if this keeps up.
Have you tried a different radiator cap?(not the lever type)
Have you 'burped' the system to get rid of any excess air in the water system?:thumbsup:
Is your douchebag vented?
Well, didn't know what else to say lol but a totally sealed system can do weird things.......and it's possible for a douchebag to overflow too and the water entering one has to displace the air that's in it. If there's no vent, it'll pressure up. Just ask any woman :D
That is very weird. Is somebody sneaking in & firing up the car? Lol, it's been couple weeks at least since you fired it up.
Anyone ever tell you.. Old Mopars are HOT running or Not..
I have used "Cool It" many times and never noticed that.Not sayin' that it didn't happen. Huh...Could be..Where do you buy "Cool It" now a days ?
You know, you're idea of a chemical reaction going on in the cooling system is a good one, seriously. Here's the safety data sheet info and link for Kool It. The only way I can see any gas forming is if you have some leftover acid in the cooling system from some type of radiator flush. Kool It is basic & shouldn't form gas bubbles on it's own.
I did here about sodium nitrite doing some weird reaction with sulfur or something (?) that was used in some radiator hoses, but that could be urban legend...just what I heard.
Was your distilled water + Kool It coolant blend pink when you added it? You want to have your coolant basic (pH >7) and phenolphthalein will be pink in this pH (if there's enough in there to see once it's diluted with water). When it gets acidic (pH <7), phenolphthalein turns clear. Low pH coolant (<8) means corrosion in your engine.
http://www.lubegard.com/pdfs/sds/SD...nt-OSHA-2012-HazCom-(Non-Corr-2015-05-20).pdf
3.1 MIXTURES
Ingredient CAS No Wt. %
Sodium nitrite 7632-00-0 0.5 - 1.5
Sodium metasilicate 6834-92-0 0.1 - 1
Sodium tetraborate decahydrate 1303-96-4 0.1 - 1
Sodium hydroxide 1310-73-2 0.1 - 1
Potassium hydroxide 1310-58-3 0.1 - 1
Phenolphthalein 77-09-8 < 0.1
I got it from Auto Plus. It's an old parts place down the road from me. I'm draining a gallon out before too long to add antifreeze. I did buy "Water Wetter" from Summit to use in the spring if I think it needs it.
3.1 MIXTURES
Wow Beeper! It might take me a few to get my head wrapped around that. Lol
It did loose some of it's pinkish color when the rust stain disappeared. It's all new, rebuilt block, new aluminum radiator ect.
I wonder if I would just get a ph kit and check it?
I'm not seeing any bubbles or smelling any weird odors but it puzzles me how it's building pressure in a day or two, sitting there cold.
Thanks for the info and data sheet.
Maybe I should drain it out and try adding some Massengill instead? :lol:
