- 5:26 PM
- Mar 10, 2010
- Hanover, Pennslyvania
Mufflers on backward?
Mufflers on backward?![]()
not sure what year your mopar 440 is but 200/220 is normal rangeUsually, even after driving around town in traffic for awhile would get to 185-190 tops...swapped the 2-1/2" pipes w/ super turbos for a 3"system w/ ultraflows. After driving around for 20-30 minutes, pulled in to the driveway and left it in gear with the E-brake on to inspect for leaks, rattles etc...noticed the temp at the neck was up to 212, with my IR gun...what the heck?? (New tti ceramic-coated headers went on too if it matters..) timing still ok at 20 btdc, idle mixture is good...your help is much appreciated!
So do I need to weld in the sensor or can I stick in the tail pipe? don't really want to remove the header to install the sensor, and don't really want the extra gauge after setting the AFR
