beanhead
Easily Offensive
Well....wanted to see what you all think. Engine has a little over 500 miles on it, a rebuild that sat for near 14 years..440, edelbrock RPM heads on plain ol' fel-pro 8519PT gaskets, cam is the compXE 21-224-4, 230/236 @ .050", 110 lobe separation, .488"/.491" lift, non-adjustable shaft-mounted rockers, 850 speed demon carb on an RPM intake. Valvetrain is somewhat clackity, when it gets warmed up. With all the flattened-lobe hysteria and such I've been wanting to get a test done, I figured it had enough miles on it (AND the tti headers did not have to be unbolted=bonus)....First firing and cam break-in was done back in February, it runs good but I'm positive it could be better if tuned better. This was done an hour or so after driving it...
#1.....160 #2.....152
#3.....155 #4.....158
#5.....152 #6.....152
#7.....150 #8.....160
What do these numbers tell me about valves operating properly, compression ratio, rings being okay etc?
