miller
What spring pressure were recommended by Crower for the roller cam? Seems those heads would have easy peasy flat tappet springs 'out of the box.'I'm inclined to think the valve springs are too weak and this may happen again on a different piston. I doubt the valve would stick open as the cylinder would push it back up
unless the valve stem is slightly bent. And that's the second issue you may have. I fear to drive with confidence, that heads going to have to come off. That or roll the dice.
I don’t know the specific spring rate recommended by Crower, but I do remember that my builder said that he checked the spring rates on the stock heads and was unhappy with them for this (hydraulic roller) build. As a result we bought and installed different springs and keepers. Interesting point though. I’ll look up what springs we bought. I guarantee i have a bill for them somewhere!
Sounds like the rockers were adjusted with no lifter pre-load? I use 1-turn pre-load, which is 0.0417" with a 24 TPI adjuster, or 0.050" with a 20 TPI adjuster. Crower recommends 0.020" min, to 0.050" pre-load.
Great and practical advice! Thank you!
The .020” preload minimum that Crower recommends is very close to half a turn (which they also recommend) based your description of the different adjuster threads. That means I’m in the safe zone again by adding a half turn of preload, and could probably go a full turn max.
