68 HEMI GTS
Sounds like a good combo, a set of TF240’s would really benefit it though over e streets.
How fast do ya want to go and how much to you want to spend?? I know several people that have gone mid 10's using the Eddy RPM heads and with stock stroke engines. Heck, my old rr went mid 10's using max ported 906 heads on a 440 but the RPM head is a better head out of the box than any 68 up stock head max ported or not. Another 440 that had an offset ground crank (470 cube) went high 9's using cast iron Stage VI heads with more cam in a lighter car. The rr would have been more streetable though imo since the cam was a good deal smaller. I remember in the 60's and 70's the thing everybody was doing was screaming short stroke engines and they did do ok. Back then I was into long stroke engines but now, it's somewhat opposite for me. So many are spooling stroker engines 7000+ rpm these days but a stock stroke 400 will turn 8k and has about the same piston speed as an engine with a 440 crank turning 7k. These days it's not hard to build a valve train to handle 7k at all and an 8k valve train isn't hard either. Rings packages are much better these days too than they were back in the cave man days lol.
Think i seen this car on your YouTube channel.View attachment 545179
500ci 74 400 block, trick flow240's 11.28@120 in a3900 lb 65.
A 470 would be an awesome way to go. I should have went that route as well, but because I do alot of driving I opted for the tried and true 451. Let me tell you that thing revs so quickly and produces tons of torque I was amazed. After speaking to several people at the track they kind of pointed out that the 451 is a great choice for the street. The biggest advantage on the 470 would be about 25 TQ that's it. If you do decide to go with 470 go with a kit like muscle motors has using 1.32 CH pistons(Same as 451 and 512) with 6.70BBC rods and a Molnar 3.91 crank. It provides the lightest assembly and a great rod ratio which will be more durable. I will post Dyno #'s of my 451 next week when I dyno it with TFS240 heads this time. Good luck on your build either way you go both will work fine.im thinking now the 470 kit from 440 source with eddy e-street heads, eddy perf. rpm intake, 850 holly DP, with mid-range cam and headers would be pretty awesome street combo. I was worried the heads may be a little small but if you guys think well ported stock heads can work, im sure it will be ok. the car isn't driven a tone (maybe once a week and just during summer months) so its not like there will be a huge amount of miles put on it. to be really honest I just want to smoke my buddy's 68 Camaro 396 when we are out terrorizing the town
So the 1975+ motors are the good ones for building stroker motors 99% of them were reinforced thicker walls ect. The 72 block ,I learned a bit about it from a friend I didn't know but there like gods of the 400 blocks for some reason he pulled one out of his roadrunner and put it up forsale had two guys show up for it they bidded it out he got a $1000 for that block! I wish I knew that because I had one out of a 72 rallye charger I sold the thing carb down for $450 I thought I did good ! (I did only pay $300 for the whole car)
But I used to toss 400's now I see the value in them grab it why you can they go quickly!
To chime in.. Lots of good info! I was thinking all the same questions. Found a later 400 block ans was thinking 470 stroker. Guys at 440 source asked why leave hp on the table if you're going to pay the same price for a stroker kit. 470 vs 512.. It made sense to me. However, I was concerned it wouldn't be streetable and tough to drive. I went 512 and kept CR lower 9.7 = pump gas! Also went with the CNC stealth heads and 571 roller cam. Been great! I can give more specifics if you need but it's just been great! No issues. Plenty of low and haven't had space to find top end yet! Good luck on your decision and build.. One thing is it will be good either way when you're done!
That’s the thing, figure if you were just Making 1hp per cube how much you’ve given up right off the bat with the cubic inch difference. 40 hp for the same price. The 511 isn’t really any different than most big block chevys people build for street engines. The amount a normal muscle car gets used, they will run along time before needing freshend. And you get this kind of performance on pump gas through exhaust.
Yea, you’re gonna have a bit more piston rock. It may need rings sooner than a longer piston. But, are you gonna drive it 100k miles? If it’s only gonna see a few thousand miles a year, the 511 is still gonna last a long time. Provided good machine work, proper clearances, and a good tune up. In my case, I hammer my stuff hard. I know in 5 years time I’ll be pulling it down for bearings and rings anyway. But that’s the case for any performance engine. You hammer the snot out of a 470 daily itlll still need maint items (bearings, rings) every so often. So will a 440. Kind of depends on what you wanna do, would I put a 511 in a car I want to drive 10-15k a year? No, I would put a stock stroke engine in it.
511 piston
