lewtot184
the magnum cam has long closing ramps. true duration at .006" lobe lift is around 276/292; almost exactly what they were advertised in the '68 road runner adds. Chrysler just ignores part of the closing ramps with the 268/284 thing."I use 213/225 @ .050, .450/.458 115 LSA. That's the factory hp camshaft."
That is about right for a Magnum cam
"BradH and others have measured it. It's nearly identical to Speed Pro CS-661, Elgin E-1094-P, etc. "
yup- same cam
Duration at .006 292/309 (SAE method .006 AT THE VALVE) or .004 at the cam with 1.5 rockers
Chrysler says 268 on the Intake
why the difference?
Chrysler has a unique yet consistent way of measuring duration. They take the blueprint point where the clearance ramp meets the acceleration ramp and add 4 degrees to the opening and 4 degrees to the close
I basically agree with 67 coronet 440- you can do better today
but 268 and 284 - the 284 is 16 degrees bigger
and the 284 is reasonably lazy and the 268 MAgnum is really lazy- so much so a fast chevy grind will look about the same
HOWEVER the MOPAR grind uses most of the .904 lifter EASILY whereas the Chevy grind would only use a .842 worth of the .904 but radically
Result- the MOPAR method wears better
the k58 is 233@.050", .514 lift.
the comp 275hl is just the xe 274 using 1.6 rockers. easy to do the math and figure that one out.
the cs661 is a magnum duplicate
the 6401 is basically crane 280/290 HP lobes on 114lsa
