Dibbons
- 5:28 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I thought I would share this message I sent to the sales department where I purchased the product:
Re: 71-74 door hinge rebuild set
The eight bronze bushings included in a small, transparent envelope included 7 of the correct bushings (outside diameter .42") and one taller and wider bushing (outside diameter .492). I believe the larger bushing is made for Chevrolet, not Mopar. I believe you owe me one bushing.
And I would like to make a suggestion that some kind of instruction is included with the package. I already wasted more than $8 for drill bit (27/64"/.4192") that seems to provide no friction fit at all for the bushings (I could push the first bushing into my 27/64" test hole by hand). It would be good to know beforehand what is the correct diameter hole for the bushing installation. I used a dial caliper to measure before shopping for a proper diameter drill bit and it seemed a 13/32"/.4063" hole may have been a little too small (tight), so I purchased the 27/64" (which now seems just a hair too large). That leaves only very odd sized drill bit sizes between 13/32" and 27/64" which are "z" (.4130") and 10.5 mm (.4134"). There is also no mention of whether the pins need some kind of staking or if they are expected to remain in place after simply tapping them in. They are too short to use any type of locking clips. I would like to finish this project using all the correct procedures but it is difficult without some guidance. Thank you.
