A case for single stage acrylic enamel
Yes, I've posted it before, bragging about the sons work! "That's my Son"!
You're not coming off cocky when you're sharing your knowledge and experience. :thumbsup:
Nothing wrong with repeat posting, i do it repeatedly. I'd brag on what my Progeny did too if had them.
Here's those Studs. White 62 has a bit of rust in tail of lft rr qtr., but rest is rust free, chassis's clean. I said Girling front discs, correction, they're Dunlop.
The 63 has had the hood & fender decks stripped, etched etch epoxy sealed, some body work w/ epoxy filler & recoated in etching epoxy primer. I love the dash & wndshield frames of these. This dash shot is the 63. The headliner shot is the 62, little messed up @ sail but otherwise decent, the stainless in & out on both of these cars is in good shape & will polish nice. White car is the 35 yr old Delstar.
IMG_20170822_181852.jpg IMG_20170822_181816.jpg IMG_20170822_181644.jpg IMG_20170822_181556.jpg IMG_20170822_181525.jpg IMG_20170822_181505.jpg IMG_20170822_181448.jpg IMG_20170822_183541.jpg
Bladecutter were you able get Dupont Centari ? I Need 1 Gal. of a dark blue for my "66 Chrysler. I have two cars that were painted with enamel over thirty years ago and they still have gloss and I maintain the finish. I look at my wife's minivan with that shitty Clearcoat pealing off and it makes the rubbing so much easier ! Oh the '71 GTX in my pic. was done with Centari 10 years ago.
Google:. Johnson Supply Company
Somewhere back east. Depending on Your location, You may be able to pick it up local to You through a DuPont jobber. It's illegal here in Cal.
I talked to Johnson a while back, they have limited Centari colors, but I feel sure there would be an opaque dark blue in the list.
Johnson Supply No longer can mix a Blue.
I ended up with a Gallon of Nason "Ful-Cryl"
Acrylic Enamel with a Pint of Hardener from a local body supply house.
Nason is low budge DuPont.
PPG discontinued Delstar altogether but I see Sherwin Williams still produces Acrylyd formula, gallon to pint. I liked Acrylyd in the day. Held out very well. Fare well with Your complete.
Thanks everyone, I called Johnsons two days ago and was told they can only mix some whites and pitch black.I wanted Dark blue.
Paints and things are changing in the autobody industry.. they backed off on alot of products here.
